Date/Time: Tue, 21 May 2024 15:01:31 +0000
Round Turn Commission and trading data file?
View Count: 569
[2020-05-18 16:47:19] |
mittalpa - Posts: 28 |
Hi I setup the "Round Turn Commission" under "Global Settings >> Symbol Settings" and refreshed logs under "Trade >> Trade Activity Log". Selected "Use Commission" checkbox also. 1. Is there a way for newly set "Round Turn Commission" to reflect in transactions done in past date range? 2. I work on two computers and want to sync transactions. Which files should I copy to sync trading data? Thanks |
[2020-05-18 18:43:46] |
1. This happens automatically. Refer to: Trade Activity Log: Use Commission 2. This is automatically supported through this service: Sierra Chart / Trading Technologies Futures Order Routing Service Otherwise, you need to copy the files in the TradeActivityLogs subfolder from one installation of Sierra Chart to another. Those files must only be copied and transferred to the other installation when neither copy is running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-18 18:54:35
[2020-05-18 19:49:32] |
Ahh .. missed to check "Custom Symbol Settings Values" earlier.. that part works now.. Follow up Q- For same product, how can I apply different commissions for different date ranges? Thanks |
[2020-05-18 20:15:58] |
This is not supported.
