Date/Time: Sat, 18 May 2024 05:12:05 +0000
Study - Lines
View Count: 512
[2020-05-17 14:27:46] |
User969241 - Posts: 76 |
I found the variable line study that can post the prior days OHLC. Is there a study that allows for custom settings of other lines? For example - If I want to post the prior days but also any day before that that has not had that particular days OHLC hit since the current day? Also - When I use the OHLC study and put the prior day in, for some reason some of the lines are slightly off from the actual OHLC. I use a 24hr market. Is there a setting I am missing? The lines are very close, but not the exact calculation. Thank you |
[2020-05-19 07:39:50] |
Have a look at the different studies here that extend until future intersection: Technical Studies Reference Also - When I use the OHLC study and put the prior day in, for some reason some of the lines are slightly off from the actual OHLC. How do you come to this conclusion? That definitely should not be the case. What study specifically are you using.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-19 07:40:40
[2020-05-19 12:41:08] |
Thanks. This just looks like a list of studies? I am familiar with many of your studies. I am looking for a study that allows for the above question I asked. I am just looking for certain kinds of horizontal lines to plot. Thank you |
