Date/Time: Mon, 13 May 2024 07:46:20 +0000
Default Text Tool Setting
View Count: 559
[2020-05-15 02:39:56] |
User148596 - Posts: 214 |
I can't figure out how to make it so when I use the text tool it automatically selects the color white instead of green. THanks, |
[2020-05-15 11:11:29] |
Refer to: Chart Drawing Tools: Using Multiple Drawing Tool Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
