Date/Time: Sun, 19 May 2024 15:32:59 +0000
High/Low Pullback Ask/Bid Diff show 0
View Count: 563
[2020-05-11 13:16:57] |
ertrader - Posts: 648 |
Hi Support... for some reason, High/Low Pullback Ask/Bid Diff show 0 (bottom two rows in the image) when using the numbers bars calculated values study. This happens regardless if data is live or replayed. I've looked at documentation and checked settings but I must be missing something. Can you please take a look? No custom studies, just numbers bars calculated values study. Windows 10 SC 2102 64 Bit Denali Data http://www.sierrachart.com/image.php?Image=1589203314274.png Date Time Of Last Edit: 2020-05-11 16:09:23
ESNUM.Cht - Attached On 2020-05-11 13:22:30 UTC - Size: 36.92 KB - 200 views |
[2020-05-11 20:47:11] |
The reason for this is described in the information for those Subgraphs in this section: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-11 22:06:52] |
Great.. thank you!
