Date/Time: Sun, 19 May 2024 13:24:27 +0000
Internal connection to data
View Count: 526
[2020-05-11 06:16:51] |
User904434 - Posts: 47 |
Please let me know how to connect to your ineternal (Sierra) data feed ?
[2020-05-11 06:42:51] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
[2020-05-11 10:15:15] |
I need only GBP futures and ES futures
[2020-05-11 11:47:07] |
In this case you will want to use the Denali Exchange Data Feed: Denali Exchange Data Feed You will need to activate the appropriate CME exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
