Date/Time: Sat, 18 May 2024 08:16:50 +0000
volume profile
View Count: 457
[2020-04-30 22:17:46] |
User779795 - Posts: 4 |
hello, I have a volume profile on my charts with a separate evening session. however, the evening session is starting at 4 am (I want it to start when the futures open at 6pm) and regardless off how many changes I make it wont create a profile that shows an overnight profile from 6 pm to 930 am and a daily profile from 930-415. can you please let me know the correct settings?
[2020-04-30 23:17:28] |
You need to set this through the Session Times for the chart. Refer to: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
