Date/Time: Thu, 16 May 2024 04:00:48 +0000
Looking for documentation on this feature.
View Count: 615
[2020-04-27 20:54:47] |
cgarrad - Posts: 27 |
I saw this formula when reading the support board: = ID0.SG4@3 > ID3.SG1@3 I can't search for it as I don't know the name of the feature, where is this documented. Thanks |
[2020-04-27 21:01:53] |
Flipper - Posts: 65 |
Study/Chart Alerts And Scanning
[2020-04-27 21:05:36] |
That is actually a formula used in Spreadsheets when using the Spreadsheet Study. So the above linked documentation is not relevant.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-27 21:46:48
[2020-04-27 21:43:06] |
Not sure why you would say it is incorrect and not follow up with the correct link but here it is anyway for those that may be reading this in the future: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study Thank you, Flipper, I found the name of the format on the page you linked at Study/Chart Alerts And Scanning: Referencing Study Subgraphs and went from there. |
[2020-04-27 21:45:57] |
We just did not yet obtain the link and post it. We were correcting the prior post. So that formula is used with the Spreadsheet Study: Overview of Spreadsheet Studies And this is the correct link which you already have: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-27 21:51:28
[2020-04-27 21:49:33] |
Thanks all.
