Date/Time: Thu, 16 May 2024 20:12:10 +0000
Old study collections and chartbooks showing up in new 2nd instance
View Count: 866
[2020-04-26 15:59:53] |
User128888 - Posts: 30 |
Hi, When I started up a 2nd instance for the first time, a new folder for the second instance is created. I saw that old version of my chartbook and old study collection that I have deleted in my main instance are showing up in my 2nd instance. Is this preventable? I want to avoid this if I were to create a 3rd instance or if I had to do this again. Thanks! |
[2020-04-27 18:34:12] |
I saw that old version of my chartbook and old study collection that I have deleted in my main instance are showing up in my 2nd instance. This is because they were already there from previously.Just delete the files that you do not want from the Data folder for that installation. Refer to: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-27 18:34:53
[2020-04-28 01:15:15] |
I checked that and it isn't in C:\SierraChart\Data which is my data folder. It seems to be pulling from my C:\SierraChart\Backups because that's the only place where I see old study collections and old chartbooks that I have deleted. However, not a big deal. Follow up question. According to this General Settings Window: Always Use 'Data' Folder within Main Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) it says new instances always use Data within Main Folder. However, when I look at the Data Files Folder of the 2nd Instance, it is using a different Data Files Folder. Attached are screenshots of my Data Folder Settings. Is this behaving as expected? Thanks. |
2020-04-27 21_10_24-Toasts.png / V - Attached On 2020-04-28 01:11:09 UTC - Size: 73.77 KB - 197 views |
[2020-04-28 10:51:26] |
No that is not even possible: It seems to be pulling from my C:\SierraChart\Backups
The main folder in this case is referring to the main root folder of the sub instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
