Date/Time: Sun, 12 May 2024 11:34:39 +0000
Fastest Sierra Charts Settings
View Count: 793
[2020-04-26 15:30:45] |
User355030 - Posts: 163 |
Can someone share that best configuration to ensure that sierra charts is running with the least amount of latency?
[2020-04-26 18:28:29] |
JohnR - User831573 - Posts: 300 |
This Support sticky section should help. [Sticky] - Recommendations to Improve Overall Sierra Chart Performance by Sierra Chart Engineering Also under Document tab on their web is FAQs Look at help topics -> 4 and 30 especially 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart JohnR |
[2020-04-27 08:18:14] |
Yes have a look at this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often In particular the section at the very bottom. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
