Date/Time: Sun, 19 May 2024 07:51:21 +0000
Cant turn off Copy Chart Drawings From Chart Numbers
View Count: 698
[2020-04-21 14:28:44] |
marketmayhem - Posts: 10 |
I somehow set my Chart 1 to get all the horizontal lines I make on Chart 5. I do not have any values in Copy Chart Drawings From Chart # is blank and both checkmarks below that option are not checked. If I go to Chart 5 and draw a new horizontal line it appears on Chart 1 also, I do have Chart 1 Copy Chart Drawings From Chart #'s set to "1" for chart 1. But it should be doing it the other way around. How do I get that to stop? TIA |
[2020-04-22 19:21:20] |
We really need to get your Chartbook to test this. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-22 23:29:46] |
File should be attached, thx
ES_.Cht - Attached On 2020-04-22 23:29:20 UTC - Size: 865.37 KB - 243 views |
[2020-04-24 07:44:07] |
We are not seeing anything incorrect in your chartbook. The Chart Drawings from Chart #1 are being copied to Chart #5 properly as per the setting in Chart >> Chart Settings >> Advanced Settings 2 >> Copy Chart Drawings from Chart #'s. We do not see any Chart Drawings being copied from #5 to #1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-24 18:32:29
[2020-04-24 13:43:37] |
Drawings or lines? -- I notice arrows and things like that do not copy but horizontal lines do
[2020-04-24 13:46:47] |
hmm idk what was going on but it does appear to be fine now. I'm sorry for this ticket but thank you for helping me with it.
[2020-04-25 01:17:08] |
The definition of a Chart Drawing is here: Chart Drawing Tools: Definition of Chart Drawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
