Date/Time: Wed, 15 May 2024 13:57:02 +0000
Add Symbols but chart data doesn't display
View Count: 478
[2020-04-17 22:44:25] |
User214233 - Posts: 7 |
I'm trying to add TICK-NYSE and NISS-NYSE to the chart but it doesn't display. I had data. I tried adding future symbols too but still doesn't show up. Please see attached what it looks like.
sierra-chart-tick-dont-work.PNG / V - Attached On 2020-04-17 22:44:07 UTC - Size: 91.23 KB - 186 views |
[2020-04-18 00:42:47] |
This is unusual. Maybe it is a color settings issue: Color Settings for Graph Draw Types Do you see a chart for those symbols when you open separate charts for them? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-18 03:41:20] |
User811622 - Posts: 38 |
I can see when I pull up TICK-NYSE in the main chart. See attached.
Attachment Deleted. |
[2020-04-19 08:07:57] |
Open the Study Settings window for the Add Additional Symbol study and check to see what the Graph Draw Type is set to: Chart Studies: Subgraphs Tab >> Graph Draw Type Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-19 13:46:21] |
I had it set to blank. After I set to candlestick, I can see the chart just fine now. Thanks so much for your help.
