Date/Time: Mon, 13 May 2024 10:36:01 +0000
Live data connection
View Count: 433
[2020-04-15 20:16:49] |
User689206 - Posts: 1 |
Hello, i would need asscistence with my first live data connection AMP Futures (contacted them several times , received my login and all is set active on their side) TT Denali Feed I cant set it up from myself as it always fails |
[2020-04-16 07:20:14] |
We want you to update to the current version of Sierra Chart. Instructions: Software Download: Fast Update And then after the update make sure the symbols of the charts are set correctly with this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-16 07:20:48
