Date/Time: Mon, 13 May 2024 07:03:23 +0000
Change Right Expansion settings
View Count: 992
[2020-04-15 19:07:27] |
User928999 - Posts: 10 |
I'm trying to get some blank space on the right side of my charts. I've followed the recommended procedure for this but still can't get any blank space to the right of the last bar. I'm sure there's a simple way to do this, just can't seem to figure it out.
[2020-04-15 19:32:10] |
Refer to the documentation here for this: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-15 23:32:17] |
Thank you for your response. After deselecting the "Allow new data in unlocked fill space" box and clicking apply I still cannot drag or move my chart freely past the most recent bar. Are there any other settings that might be restraining my ability to move my chart freely?
[2020-04-16 18:47:00] |
Make sure this is unchecked: Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu) ----- Also you will not be able to scroll the chart back when all of the data is currently displayed in the window. In this case, you will not be able to select the scroll bar to move the chart either direction. To overcome this, just expand the time scale so there is more data than what fills the screen. Refer to the information here: Working With Charts: Scrolling The Chart and Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-16 18:47:18
