Date/Time: Sat, 27 Apr 2024 06:13:11 +0000
[User Discussion] - Volume based rollover incorrect
View Count: 795
[2020-04-07 20:12:28] |
User650446 - Posts: 11 |
Many people I know that uses SC has ES rolling over on 3/16 using CBV with a price difference of -42.25. Mine rolls over on 3/13 using CBV with a price difference of -12.5. I've deleted all ES SCID data and checked that there are no custom rollover adjustments in the symbol settings. My TPO charts are essentially 30 points different than others. Of my 2 comparisons, we are both using CQG. |
[2020-04-07 23:03:42] |
The correct rollover is on March 16 and the adjustment amount is as follows: ESM20 [CBV][M] Daily #18 | Back adjust amount for symbol ESH20 is -42.25. | 2020-04-07 19:01:50.478 Follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data When you perform a re-download of the data, enable the Download for Daily Data Files Only option on the Symbol list window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-07 23:04:14
[2020-04-08 00:27:40] |
Thank you so much! That worked! I thought I tried everything already mentioned in the previous responses to this issue. Is there a way I would know something is wrong in the future instead of having to compare with someone else? I'm worried that if I don't regularly compare with someone, I'd have no idea that my TPOs are screwed up (or that I'd regularly have to perform these steps). |
