Date/Time: Wed, 15 May 2024 20:44:21 +0000
Continuous contract data is re-downloaded on startup
View Count: 721
[2020-04-06 12:01:31] |
User816220 - Posts: 80 |
Under certain circumstances, SC will re-download continuous contract data on startup. - Must be starting a sub-instance - Chartbooks are set to open on startup - The same symbol is open in multiple chartbooks - At least one of the charts for the symbol is set to continuous contract When those conditions are met SC re-downloads the full set of continuous contract data for the affected symbols, which can add several minutes to the startup time. The issue persists after following the procedure to re-download data in the main and sub instances Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data |
[2020-04-15 18:31:26] |
We apologize for the delay. This issue is now resolved. Update to the latest prerelease following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-15 22:21:06] |
User267701 - Posts: 66 |
I can confirm this as well. I use SC v2086. I used the delete and download option in the main instance. Didnt work....still re-downloading on startup. So i deleted manually all daily symbol data files in all instances. Now it works like a charme again. SC loads all my charts in roughly 1min. Date Time Of Last Edit: 2020-04-15 22:27:58
[2020-04-15 22:37:02] |
Not sure what to say about post #3 without further analysis. We would not expect there to be any further problem but if you no longer have it we just have to let it go for now.
[2020-04-15 23:21:57] |
2086 fixed the issue, but just for the record I saw the same thing as post #3. On the first startup after updating to 2086, the issue remained. After deleting all data and re-downloading, the issue did not occur on subsequent startups. |
