Date/Time: Sun, 19 May 2024 02:03:05 +0000
SC Dome does not show SP emini action
View Count: 595
[2020-04-03 15:07:16] |
PaulC - Posts: 16 |
It us suggested that SC dome shows the real time Emini S&P activity as well as previous day Hi & LO thank you
Date Time Of Last Edit: 2020-04-03 15:07:41
[2020-04-04 09:52:00] |
You can display the previous day's High and Low on the DOM using the Daily OHLC study and setting the subgraphs for the High and Low to Subgraph Name and Value Labels Only. By default, the Daily OHLC is set to display the previous day's values since the Input for Reference Days Back is set to 1. Refer to the information here for the Daily OHLC study: Daily OHLC And refer to the information here to set the Subgraph Draw Style: Chart Studies: Subgraphs Tab >> Draw Style And refer to the information here for the Name and Value Labels: Chart Studies: Subgraphs Tab >> Name and Value Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
