Date/Time: Tue, 07 May 2024 08:18:39 +0000
Different prices on support and resistance level between continuos and current contract
View Count: 554
[2020-03-27 10:15:11] |
Fabio - Posts: 111 |
Hi there. I have a strange thing happening to me on some charts, especially on commodities. I have loaded 2 charts for the same market, one where I have the continuos contract showing the daily chart and another one with the same month contract with which the continuos contract has been built but without continuous activated (i.e. NGK20 and NGK20 + continuous function activated). When I mark levels on the continuation contract to help me with support and resistance levels on lower timeframes, the lines are drawn on completely different levels between the 2 charts. I thought it was due to the calculation for the continuous contract but I tried all the options available for the continuations settings but nothing has changed. Please find attached an example, I uploaded from here because it's on 2 different monitors. Can you please help me? thanks, Fabio. |
Untitled.png / V - Attached On 2020-03-27 10:14:12 UTC - Size: 159.52 KB - 210 views |
[2020-03-27 20:45:35] |
If the continuous futures contract chart has back adjusted prices, that would be one reason. And you need to make certain you know what contract month you are looking at in the chart at a particular chart bar. Refer to: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-27 20:46:11
[2020-04-06 08:32:26] |
Hi there. I tried and followed all the manual but no solution has been found. The manual talked about some differences in the charts between continuous contract and not, however, there is no specific explanation on how to solve this problem. I already tried all the settings of the case, including evening sessions, reverse session times, etc. But none of them solve the problem. I tried already (before contacting you) to play around with the continuous contract settings (i.e. date rule rollover, volume-based rollover, etc). I literally tried all of them but unsuccessfully. The difference across the charts remain the same. Actually, switching between future contracts rollovers will adjust the price upon or down but none of them match with the intraday chart I'm looking at. Can you please help me out? Many thanks, Fabio. |
