Date/Time: Sun, 28 Apr 2024 20:36:53 +0000
Did AMP Futures implemented the new SC order routing service?
View Count: 860
[2020-03-25 18:57:11] |
SKZ90 - Posts: 74 |
See attached picture. Are we still following the instructions in Sierra Chart / Trading Technologies Futures Order Routing Service ? |
Futures Month Code.PNG / V - Attached On 2020-03-25 18:54:43 UTC - Size: 204.36 KB - 231 views |
[2020-03-25 19:00:04] |
Yes this is fully supported by AMP.
[2020-03-25 19:11:34] |
SKZ90 - Posts: 74 |
Do we still submit the request form "to add your trading account to the Sierra Chart company TT FIX connection for order routing"? I want to use the SC Order Routing service and Sierra Charts charting platform, and not the AMP service. I'm still on the free trial but want to transition to the paid service soon. |
[2020-03-25 19:58:28] |
Yes you still need to complete that form. If you want to use AMP as your broker, you need to have a trading account with them. There is no way to bypass that. But there are other clearing firms/brokers you can work with which support this service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-25 20:06:18] |
SKZ90 - Posts: 74 |
I'm coming from Interactive Brokers, so I'm used to everything being commingled together. So, 1. AMP is the broker where my funds are stored. 2. SC provides the order routing service for the funds 3. SC provides the charting platform to use the SC order routing service. Am I getting this correct? For other brokers or services, AMP seems to be the cheapest route for now. But definitely will be using Sierra Charts order routing technology services and its charts. Also, I denied any market data from AMP since I'll be using Sierra Charts order routing technology. I hope I did that part correctly. I don't want to be double charged for the same service. |
[2020-03-26 04:34:14] |
1, 2, 3. Yes this is all correct. Also, I denied any market data from AMP since I'll be using Sierra Charts order routing technology. Yes this is fine.
