Date/Time: Sat, 04 May 2024 01:20:02 +0000
[User Discussion] - SIERRA INEXPLICABLY SLOW ALL OF A SUDDEN.
View Count: 485
[2020-03-25 17:01:19] |
User725605 - Posts: 60 |
I have noted in the past week that my Sierra has 'inexplicably' slowed to a crawl. If I am able to get my cursor to click on something I get the blue circle hanging and the program often freezes. All was working fine until this. I tried closing some charts to see... but no diff. In task manager Sierra shows that it is pulling an inordinate amount of power and flashes "not responding," off and on. The rest of my computer - Windows 10 - is functioning perfectly, and very fast as always. Please advise how to remedy. |
[2020-03-25 18:48:29] |
Refer to help topic 30.48: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart There is also a helpful video at the bottom of that section. Be sure to review it. If nothing has changed on your side, then the problem would be due to the wider price ranges in the market and increased volumes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-25 18:49:44
