Date/Time: Sat, 04 May 2024 13:31:21 +0000
Tool Button graphics missing
View Count: 504
[2020-03-24 15:22:38] |
User80177 - Posts: 29 |
Hi, After updating to latest SC version, the tool bar button graphics are missing, showing only text description instead. The Stationary Text tool does not work although this is a a problem that appeared in a previous version of SC and was not resolved with the update of the new version. Pls advise. Thanks. |
[2020-03-24 23:55:59] |
For the first issue, refer to the first item in the Version Notes for version 2065 here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 What is the problem you are having with the Stationary Text Tool? We do not see any issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-25 04:58:55] |
Re: Stationary Text Tool. I was using SC ver 1830 for sometime and the tool worked alright. Since a couple of weeks ago, the Stationary text entry window does not appear when I click on the Stationary Text tool button or from the Tools menu. The Text tool is working normally. I also tried re-starting SC, creating a new chartbook and new chart and it is not working. The problem is not resolved with an update of SC to the latest version. So it might be a problem with a user config file. Any suggestions please? Thanks. |
[2020-03-25 13:51:22] |
John - SC Support - Posts: 31362 |
Go into the Tool Configuration window that is selected for this drawing tool remove any preset text. Refer to the Tool Usage section of the following for more information: Chart Drawing Tools: Type Text | Stationary Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
