Date/Time: Thu, 10 Jul 2025 02:44:25 +0000
[Programming Help] - lowest value in a column
View Count: 598
[2020-03-24 05:49:42]
User917679 - Posts: 76
In spreadsheet programming, what would be an efficient way to go about finding the lowest value out of x number of rows in a given column?
I found this: SMALL(Numbers, NthSmallest), but how would I go about using it to do the above(Or should I even use it at all..)?
[2020-03-24 12:38:09]
Sawtooth - Posts: 4236
Use the MIN function.
If you want to exclude Zeros, use the MINZ function.
If you want to include only those values Greater than a given value, use the MING function.
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#MIN_Function.
To also limit the number of rows, use the OFFSET function.
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#OFFSET_Function
Try something like this, e.g. in cell P3:
=MINZ(E3:OFFSET(E3,x,0))
where x is the number of rows.
Date Time Of Last Edit: 2020-03-24 13:25:45
[2020-03-24 13:57:01]
Ok and from here, how would you obtain the "cell address" that houses this minimum number?
[2020-03-24 14:30:46]
In another Formula Column:
=P3<>P4
This marks the row with a '1' where the lowest value occurs.
Date Time Of Last Edit: 2020-03-24 15:39:39
