Date/Time: Fri, 03 May 2024 10:36:55 +0000
activation
View Count: 415
[2020-03-24 03:46:43] |
User752134 - Posts: 2 |
Hello, I'm trying to set up a CQG data feed. I started Sierra Chart trial through AMPfutures. They said it's free for package 3. I have login details for CQQ, but I can't see on the platform how to login. Can you help? Clare |
[2020-03-24 11:57:55] |
Sierra Chart does not support CQG demos if that is what you are referring to. Refer to this page for the solution: Basic Instructions for Sierra Chart Demo for Brokerage Customers If you have a live CQG account, refer to: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
