Date/Time: Fri, 03 May 2024 08:42:14 +0000
Daily PnL Discrepancy
View Count: 662
[2020-03-23 18:19:39] |
User703334 - Posts: 59 |
See attached. Entering today with zero trades my balance was $616.97 I then traded today as the DPL windows indicate. I traded nothing else than what I have shown in the attachment, i.e., just the /es and /nq micros. The DPL windows are indicating a small profit. However, the discrepancy is my Account Balance Window is showing a $114.95 loss. Are my DPL windows accurate? If not, how do I make them accurate? I've never had a problem with the DPL windows prior to this. This is a very large discrepancy. Thank you, |
Daily PnL.JPG / V - Attached On 2020-03-23 18:19:28 UTC - Size: 128.22 KB - 219 views |
[2020-03-24 12:11:35] |
Refer to this page: Help With Daily Profit/Loss Value Also make sure the Currency Value per Tick setting is correct, being you are using micro contracts: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-24 12:13:38
