Date/Time: Fri, 03 May 2024 10:52:15 +0000
The Cost of Using Rithmic is going to Increase Due to CME Market Data Policy
View Count: 1353
[2020-03-23 10:19:27] |
From Rithmic: As many of you know, the CME Group is increasing the real-time market data subscription fees for non-professional market data subscribers to depth of market, effective 01 April 2020. Additionally, the increased fees will be applied to each user id that is entitled to access the CME Group’s real-time market data, multiplied by the maximum number of concurrent sessions (the max session count) permitted for that user id. For example, if, during April 2020, a user id for a non-professional market data subscriber is entitled to access real-time market depth data from all 4 of the CME Group’s exchanges and has a max session count of 3, the fee incurred by that user id for April 2020 will be the applicable rate multiplied by 3 (the max concurrent session permitted for such user id) even if the user id logged in 2 or fewer times concurrently, or even if the user id did not login at all.
Members of proprietary trading houses should contact their prop shop to obtain information about fees for prop shop traders. At this time, plug-ins to apps that login for real-time market data do not incur additional market data subscription fees. Consequently, Rithmic will be modifying R | Trader Pro to accept plug-ins and will be modifying Rithmic’s R | API+ and R | Protocol API to connect to R | Trader Pro, provided that apps that connect to R | Trader Pro run on the same machine as R | Trader Pro. Although this modification to R | Trader Pro currently is under development and not yet available, Rithmic plans to modify R | API+ and R | Protocol API immediately so that current apps incorporating either of those apis need only modify their connectivity modules, not their functionality. This means that a market data subscriber who generally logs in with several apps concurrently, will be able to plug them in to R | Trader Pro and not incur additional market data subscription fees for their use. Of course, apps that do not incorporate the new versions of R | API+ or R | Protocol API will be able to continue to login, but may require a higher max session count and, therefore, incur higher fees. For more information regarding fee changes and market data policies of the CME Group, please visit the CME Group’s website. Since we have ceased all development for Rithmic, we will not be supporting any new API from Rithmic. Therefore, the cost of using Rithmic is going to increase significantly if you require two concurrent sessions. You have to pay for the CME fees for Rtrader and then you have to pay them again for them for Sierra Chart. If you require market depth data, this then becomes a cost of 60 USD per month plus the 20 USD month monthly fee for Rithmic. The alternative is if you are doing live trading is to use the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service Additionally, Sierra Chart fully supports sharing data on the same system among multiple installations of Sierra Chart. This is explained here: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-23 10:22:51
