Date/Time: Mon, 06 May 2024 04:44:50 +0000
SC for charting only
View Count: 535
[2020-03-20 21:41:10] |
Cristian.Ivanov - Posts: 9 |
Hi, I'm interested for using SC for charting only for micro ES mini futures. I'll use SPack 5 but don't know what data feed to chose. Thank you for suggestions. |
[2020-03-22 00:57:13] |
If 10 minute delayed data is acceptable, we recommend using this data feed: Delayed Exchange Data Feed Make certain you update to the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-22 00:57:38
[2020-03-23 16:37:05] |
No. I need real time data
[2020-03-23 18:19:09] |
In regards to real-time data, refer to: Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
