Date/Time: Sat, 04 May 2024 23:52:35 +0000
hi i do not see data since 0930. diconnected reconnected... noth
View Count: 459
[2020-03-20 15:18:13] |
User528915 - Posts: 5 |
OK understood...esh20 is finished?... moved to esm20. you do not send a note or specific date for the change? |
[2020-03-20 18:45:15] |
Enable this option: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
