Date/Time: Mon, 06 May 2024 01:07:13 +0000
S&P 500
View Count: 537
[2020-03-20 15:08:23] |
User56075 - Posts: 4 |
Hi I have the advanced 5 package. I was trying to ddownload the S&P 500 chart but could not do it. Is that not included in the package? Thanks
[2020-03-20 17:43:33] |
Yes it is, but you are running a significantly older version of Sierra Chart. You must update to the current version following these instructions: Software Download: Fast Update Did you want the cash index chart or the futures chart? The newer versions, support the delayed exchange data feed for delayed futures data: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-20 17:45:25
