Date/Time: Tue, 07 May 2024 08:04:13 +0000
Horizontal Lines Study
View Count: 799
[2020-03-20 14:36:53] |
User750920 - Posts: 274 |
Hi, when using the Horizontal Lines Study it allows for up to 59 lines. I am using say 5 lines and the rest are set to ignore in the subgraph. If I then show Compact Tool Value Window and then go to that chart where I have the Horizontal Lines study theTcompact tools value window shows not only the lines I have enabled but all the rest up to line 59 (even though they are set to ignore the value in the compact tools window show 0). Is there a way to set it up so the Compact Tools Value Window only shows the lines I want and not the rest. Thanks |
[2020-03-20 16:36:45] |
John - SC Support - Posts: 31419 |
For each subgraph that you do not want to have displayed in the Tool Values Windows, you need to uncheck the option for Display Name and Value in Chart Values Window. Refer to the information here: Chart Studies: Subgraphs Tab >> Display Name and Value in Chart Values Windows You can then save that configuration as the default for the study going forward. Refer to the information here for how to do this: Chart Studies: Using Custom Default Study Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-20 17:56:40] |
Thanks.. let me confirm - do I have to do this for each line one at a time in the subgraphs tap or is there a way to do this faster?
[2020-03-20 18:00:28] |
Yes. We will look at changing the default value for those.
[2020-03-20 18:02:05] |
Thank you.
[2020-03-20 18:24:59] |
Another thing. I have 2 charts up with the same two studies in them in a separate pane. The pane contains a symbol - the TICK-NYSE and the Horizontal lines. In one chart the Compact tool values window displays only the TICK-NYSE and not the Horizontal lines (Which is what I want). The other displays the exact opposite.(does not display the TICK-NYSE). The only thing different when I look at the pane is the title bar of the pane where it lists what is in the pane. The one that is correct. lists the TICK-NYSE first and the Horizontal lines second the other is exactly the opposite. It seems there is a priority to what is listed first. How do I reverse this. BTW it is occurring on another chart too with a different added symbol (the NISS-NYSE) and the Current price line study. Need to reverse that too.
[2020-03-20 19:34:24] |
I figured it out. - I simply moved the study below the other study in the Study to Graph window of the Chart Studies.
