Date/Time: Sun, 05 May 2024 16:58:34 +0000
How do I add a seperator line to studies?
View Count: 544
[2020-03-19 13:40:35] |
grantx - Posts: 244 |
Chart Studies: Hiding and Showing Study Directly from Chart You see how when you add volume at the bottom in region 2, there is no seperator line between region 1 and region 2? How do I add a horizontal line so that I can clearly see where the chart stops and the study starts? |
[2020-03-19 15:12:01] |
John - SC Support - Posts: 31379 |
Refer to this setting: Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
