Date/Time: Thu, 02 May 2024 06:21:36 +0000
Instance 2 crashing
View Count: 439
[2020-03-18 23:57:45] |
User48838 - Posts: 112 |
I have 4 Instances. Instance 2 and 3 have the same chartbook, but with a different symbol on each, ES is #3 and NQ is #2. I closed the chartbook on #2 and copied the ES one from Instance 3, changed the symbol to NQ and renamed the chart book. It still crashes. Any ideas? Thanks.
[2020-03-19 03:50:38] |
Run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode If you still have a problem we need to get the Chartbook and test it. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
