Date/Time: Tue, 07 May 2024 12:39:33 +0000
Funding account
View Count: 540
[2020-03-18 19:39:16] |
User5775 - Posts: 3 |
I presently have 2 Ninja IRA accounts and just opened a Sierra account. How do I switch them over to using Sierra charts ? Or do I need to close the Ninja accounts and transfer the funds out of those accounts and establish new ones with Sierra. Thank you Kevin
[2020-03-18 21:49:31] |
Did you want to trade those accounts through Sierra Chart?
[2020-03-19 14:02:07] |
yes
[2020-03-19 16:51:14] |
If they are set up on CQG, then you would need to have Ninja trader authorize those CQG accounts to allow Sierra Chart to connect to them. That is going to be an extra cost. We have more information about this here: Using Sierra Chart with Ninja Trader Brokerage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
