Date/Time: Wed, 01 May 2024 03:54:55 +0000
data bursts
View Count: 14745
[2020-03-18 19:09:12] |
User894467 - Posts: 19 |
I am seeing data come in 1 second bursts. Is there a setting to increase to data flow so that it does not fill in every 1 second or so? F.US.EPM20 |
[2020-03-19 03:19:00] |
Check the Chart Update Interval: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Also refer to: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading If this is data feed specific issue we recommend using the Denali exchange data feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
