Date/Time: Sat, 04 May 2024 16:04:54 +0000
QuoteBoard displaying wrong high/low
View Count: 523
[2020-03-17 23:47:16] |
User403999 - Posts: 3 |
After I did the upgrade my QuoteBoard doesn't display the accurate High or Low of the day. It appears to be some combination of recent price action as opposed to the entire day. I enabled market depth data but that didn't fix it.
[2020-03-18 03:28:22] |
This is a Transact data feed limitation. Consider using the Denali Exchange Data Feed: Denali Exchange Data Feed You can use this data feed and still use Transact for trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
