Date/Time: Mon, 06 May 2024 10:57:32 +0000
Alert Manager Message Window
View Count: 742
[2020-03-18 06:54:36] |
Here is the relevant setting: General Settings Window: Show Alerts Log On Study Alert (Global Settings >> General Settings >> Alerts >> Additional Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-18 18:10:52] |
If you want to use email alerts, then enter your email address in Global Settings >> General Settings >>Alerts >>Email Address. And if you post again, we need you to log into this Support Board with your active account. Do that with Help >> Support Board from within Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-18 18:16:23
[2020-04-16 22:17:49] |
whats1thingnow - Posts: 407 |
i'm getting the alert manager window popping up and i don't want this in the middle of trading General Settings Window: Show Alerts Log On Study Alert (Global Settings >> General Settings >> Alerts >> Additional Settings) the option is DISABLED, i have never turned this on If the Alerts Log opens even when this option is disabled, then this would indicate the message is being added by an Advanced Custom Study, which is causing the Alerts Log to always open. The custom study itself will need to be modified to prevent this.
i don't use Advanced Custom Study I use many instances of Color Bar Based On Alert Condition for multiple charts please help, i don't want it to automatically open |
[2020-04-17 18:52:01] |
Copy and paste the Alert Log line here which is added at the time the Alert Log is opening.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-17 18:52:12
