Date/Time: Tue, 30 Apr 2024 05:20:43 +0000
Ninja Trader Data Feed
View Count: 934
[2020-03-17 17:19:25] |
User755412 - Posts: 14 |
Can I use my Ninja Trader login info to get live data?
[2020-03-17 18:21:06] |
No. Refer to this page: Using Sierra Chart with Ninja Trader Brokerage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-17 19:30:01] |
what do you recommend as a better brokerage house than Ninja with similiar margin rates and brokerage costs? thanks
[2020-03-18 06:41:45] |
Check with the following: AMP Dorman Advantage Stage 5 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-18 19:54:30] |
And these brokerage houses are compatible with you program? Ie I will be able to use those logins to obtain a live data feed?
[2020-03-18 20:16:58] |
Yes. Full compatibility. We would recommend that they set you up on TT (Trading Technologies) and then the TT account would be assigned to your Sierra Chart account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
