Date/Time: Sat, 18 May 2024 21:06:27 +0000
Limit Down Issue
View Count: 473
[2020-03-16 13:28:22] |
User94606 - Posts: 327 |
When there is a limit down, the SierraChart platform freezes. Is there a way to avoid the freezing even when there is limit down?
[2020-03-16 18:03:59] |
This cannot be technically correct. There is another explanation for the issue in your case. Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Also refer to this video: https://www.sierrachart.com/Videos/Improving_Sierra_Chart_Performance.mp4 ----- What do you mean by "freezes". Certainly if there is a Limit Down there is not going to be any new data loaded until after the appropriate time has passed. But you should still be able to interact with the program. Let us know if there is something specific happening where you can't interact with the program. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-16 18:22:26
