Date/Time: Sat, 27 Apr 2024 23:27:29 +0000
Data loss problem
View Count: 1468
[2020-03-03 17:07:22] |
User821468 - Posts: 84 |
Recently ive been experiencing frequent loss of data shutdowns, not sure if my end or excessive volatily and speed of market recently. please advise im running on ver 2059/64
[2020-03-04 20:02:01] |
Data loss and frequent shutdownd persisting today with v2061/64 while on SimLive.reluctant venturing on live , suggestions appreciated are these interruptions expected on Live server as well?
Date Time Of Last Edit: 2020-03-04 20:04:30
[2020-03-04 20:17:51] |
Transact is aware of the issue, and they have implemented performance improvements on their side which we have then implemented correspondingly on the Sierra Chart side. We recommend you update to the latest prerelease with Help >> Download Prerelease.
[2020-03-04 20:58:29] |
Thanks but is this problem existing also in the live server ?
[2020-03-04 21:47:39] |
You will need to ask Transact that question.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-05 17:38:06
[2020-03-05 18:21:18] |
transact advised that live and sim are same feed, Noticed in ver 2061/64 prerelease control bar shows drawing studies by description rather than icons showing what the study looks like..could you please reverse that? graphic representation of studies much more convenient than descrptive representation. thanks |
[2020-03-06 04:49:39] |
To use the default image for a button, follow the instructions here: Control Bar: Control Bar Button Properties It is explained specifically at step 10. But you need to follow the beginning steps to open the button properties. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-06 12:19:34] |
thanks that did it
[2020-03-06 13:34:52] |
Lost connection again today 830 am coincidental with jobs report suggesting continued relation to volume and volatility. on Ver 2062/64 Sim
Date Time Of Last Edit: 2020-03-06 15:54:55
[2020-03-06 17:30:21] |
Okay but this is a Transact data feed issue.
[2020-03-20 14:02:27] |
I noticed recently that my alert manager screen does not report a formula error I know I intentionally introduced an error in a formula by substituting an "i" instead of a "1". The study doesnt execute on the chart but no error is given in the alert manager. after I remove the error, the formula executes on the chart. The only change to my set up is I added 8 GB ram memory to 16Vs 8 before .to my Core i5"i5" computer running win 10 on Ver 1067/64. The freqeuncy of data losss seems reduced by he upgrade but not totally eliminated. Protected mode didnt help either. Would welcome a remote assistance from SC to look at my setup and computer since Transact isnt much helpful. my phone is (904) 272-3407 est 8-4 pm Date Time Of Last Edit: 2020-03-20 17:15:23
[2020-03-20 17:47:39] |
We do not provide any technical help for the Transact data feed or any external data feed. Those are beyond our control.
[2020-03-20 17:48:37] |
It is entirely possible that your formula was still valid with that character change. We would need to see the formula. As to the issues with the data, that is related to the Transact data feed. The only thing we can do is recommend you use our Denali Data Feed in order to alleviate the issue. You will find more information on the data feed here; Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-21 09:46:58] |
With regards to the Denali Feed and your reference, I am at a total loss following these instructions to get the Denali feed. I would appreciate a remote assistance to help me with the Delali feed. Iam a non commercial user,interested only trading the emini Es intraday and lookback a couple of days using the Sierra charts and allowing transferring my SC formulas and studies having invested a couple of years in them. I would need guidance locating and signing up with a firm that uses SC and the Denali Feed.My phone is (904) 272-3407, 9-4 pm EST thank you.
[2020-03-23 13:24:37] |
your comments appreciated thanks
[2020-03-23 14:11:00] |
SC Support - Posts: 1795 |
Hi Paul, we missed you with our call today, we can try later when you have time.
[2020-03-23 14:38:07] |
never missed a call today. What is your caller id. please answer message i'll pick up. I usually dont answer unknown caller id's due to spam calls thanks
Date Time Of Last Edit: 2020-03-23 14:43:17
[2020-03-27 19:49:45] |
Following my earlier communication with Ray,Urgently need to communicte back with "Ray" on Wed April 1 2020 To establish new account with Denaly feed and new broker and Sierra Charts. I will be discontinuing my account with Tranansact effective April 1 2020 and will need to reconnect with Ray's help to new Broker and Denali Feed. my phone is (904) 272-3407 Thank you
[2020-03-27 20:46:15] |
Spoke to User821468 again, arranging for a Remote Assistance session.
[2020-03-28 14:11:58] |
For Ray I would appreciate notifying me on cell by text at (904) 887-2980 within a couple of hours the approx time you are expected to call on land line at (904)272-3407,in order to be available and ready in front of computer. I will respond with the soonest I could make it, including immediately, if I can Thank you Date Time Of Last Edit: 2020-03-29 13:02:09
[2020-03-29 23:58:59] |
Hi User821468, we will reach out to you on Monday, in the afternoon US time. We will drop you an email to set that up.
