Date/Time: Sat, 18 May 2024 15:57:15 +0000
Problem with CBOT ZN price
View Count: 827
[2020-03-03 13:17:07] |
User310898 - Posts: 35 |
Hi On my sierra chart as well as DOM the price for the CBOT 10y treasury note is showing incorrectly as fractions of 34. My understanding is it should be priced in fractions of 1/32. The same problems occurs on my chart. Also on my DOM the price does not show correctly as for example 134'26, 134'265, 134'27, 143'275 ie in increments of 0.5/32nds. It just shows as repeating numbers. 134'26, 134'26, 134'27, 134'27. I am unable to attach a screenshot. I can email it to you. I use sierra chart data feed, symbol is ZNM20_FUT_CBOT. Grateful if you can have a look at this. I have gone into settings and changed it to 1/32 but the DOM goes haywire and doesn't like it. Thanks! |
Attachment Deleted. Private File |
[2020-03-03 18:07:58] |
Update Sierra Chart to the current version: Software Download: Fast Update There is a technical notice about this when you start Sierra Chart. Let us know if you have any further issue with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-03 18:08:12
[2020-03-03 20:30:46] |
Thanks, however as part of my Sierra Charts data via AMP solution I was told "This makes market data access completely seamless without any intervention on your part to connect to a funded trading account once a month. The authorization is simply automatic without doing anything. Although this requires Sierra Chart version 2033 or higher for this." I was told to install the pre-release. Easy Solution to CME Funded Trading Account Requirement Is installing the current version going to cause a different problem given this? Thanks |
[2020-03-03 21:40:10] |
Installing the current version will not cause any issue.
