Date/Time: Sun, 04 Oct 2026 13:21:25 +0000
Missing market depth after upgrade to v2057 (64 bit)
View Count: 851
[2020-03-02 17:50:12]
mbilyanov - Posts: 62
I'm not sure if this is because I have upgraded or something else, but the market depth is missing now. Please see the images. I'm also on the Denali Data Feed, maybe something changed there?
The first image shows the missing depth, the second one shows how things were last week.
Thanks,
M.B.
imagesc_missing_depth.PNG / V - Attached On 2020-03-02 17:49:12 UTC - Size: 56.39 KB - 319 views
imagesc_missing_depth2.PNG / V - Attached On 2020-03-02 17:49:21 UTC - Size: 815.95 KB - 370 views
[2020-03-02 17:54:00]
User487595 - Posts: 14
Yes I'm having the same problem but with CFE, last night I was getting full depth for all the levels now it only shows the current bid/ask
[2020-03-02 18:08:14]
Ok. Good to know it is not only me.
[2020-03-02 18:37:58]
Both of you are describing two wholly different issues. They are unrelated because they involve different exchanges.
Make sure you are connecting to your live Interactive Brokers account:
And check this Chart Setting:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) (Maximum Market Depth Levels)
[2020-03-02 19:05:12]
I can confirm that (without actually changing anything) after I have upgraded to v2058 (pre-release), I no longer experience the problem.
