Date/Time: Sun, 19 May 2024 11:19:23 +0000
error en inicio de sierra chart
View Count: 544
[2020-02-25 03:42:33] |
Mountain_Trading - Posts: 1 |
Hola, estoy queriendo abrir una cuenta real a través de AMP FUTURES y utilizar este software. Ya lo había utilizado en versión demo y con éste ordenador. Pero ahora, en real, quiero utilizar otro nombre y mail. Pero al querer iniciar sesión, me arroja un error. Debe estar detectando el IP de mi máquina. Cómo hago para tener nuevas claves y nombre para mi cuenta real?
[2020-02-25 15:57:44] |
Translated from Google Translate: Hello, I am wanting to open a real account through AMP FUTURES and use this software. I had already used it in demo version and with this computer. But now, in real, I want to use another name and mail. But when I want to log in, I throw an error. You must be detecting the IP of my machine. How do I have new keys and name for my real account?
The account that you have posted from is valid and has a Trial associated with it that will end on 2020-03-10 23:59:59 UTC. If you are having trouble with a different account, then please let us know that account name. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-27 04:51:58] |
After the message above was posted, the trial was blocked based on standard rules. We have activated your trial for another 5 days. We see you have set Sierra Chart to use CQG, if you do not have a live CQG trading account, then use the simulated trading service: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
