Date/Time: Mon, 29 Apr 2024 16:15:23 +0000
crosshair calculating the price difference on the fly
View Count: 706
[2020-02-18 13:51:08] |
dmnk - Posts: 6 |
Hi, is there a way for crosshair to display the difference (in ticks, currency, or %) from the current price? Eg. the price is 100, I hover over 75 and crosshair shows: 75.0 (-25.0)
[2020-02-18 18:14:07] |
The closest available is the Chart Calculator tool: https://www.sierrachart.com/index.php?page=doc/Tools.html#top Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-25 07:41:47] |
microcomp - Posts: 21 |
Is there a way to add the Chart Calculator function to the Crosshair Tool? So that we could use the crosshairs to measure the pips between the top and bottom of the candlesticks? Sometimes in Green Charts we use the Crosshair Tool to line up an indicator with a candlestick but then have to switch over to the Chart Calculator tool to do measuring, which then loses the alignment of the crosshair. Just a thought for something to do, someday when your not busy. If that ever occurs in this decade. Thanks again for all your help and support.
[2020-03-25 08:29:58] |
You can change the Action When Other Tools Selected to Always on When Using Other Tools: Chart Drawing Tools: Chart Values Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
