Date/Time: Sun, 12 May 2024 05:56:33 +0000
Bitmex - Orderbook range on chart
View Count: 601
[2020-02-17 17:07:37] |
dmnk - Posts: 6 |
Hi Support, Can you advise how to increase the range of orderbook displayed on the chart? At the moment only 100 USD range is shown: http://www.sierrachart.com/image.php?Image=1581958293463.png Thanks |
[2020-02-17 20:55:06] |
Refer to this setting: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-17 20:55:15
[2020-02-18 06:08:43] |
dmnk - Posts: 6 |
It's much better now - I set Depth to 0 and the range increased, covering 9400 to 10200, but the whole orderbook still isn't displayed (it spans 0-25000). Settings: Global Settings >> Data/Trade Service Settings >> Max Time & Sales Depth Levels = 0 Global Settings >> Data/Trade Service Settings >> SC Server Settings >> Max Depth Levels = 0 Chart >> Chart Settings >> Advanced Settings 3 >> Maximum Market Depth Levels = 0 Chart >> Chart Settings >> Advanced Settings 3 >> Number of Levels for Bid/Ask Depth Calculatiion = 0 I did reconnect and also restated the program after applying the settings. Date Time Of Last Edit: 2020-02-28 16:49:16
