Date/Time: Sun, 12 May 2024 05:08:26 +0000
Check if SC is using correct data feed
View Count: 472
[2020-02-17 15:45:47] |
User145798 - Posts: 4 |
Hello, How can I check if my Sierra instance is using SC routing for getting the tick data instead of my brokers data ? Which is Interactive Brokers I'm trying to make sure I get real tick data from my Sierra Chart subscriptions for EUREX and not the datafeed from Interactive Brokers Thanks a lot |
[2020-02-17 21:09:01] |
You can tell if the data is from the Sierra Chart Exchange Data Feed if there is an [M] after the symbol in the top line of the chart. Refer to the information towards the end of this section: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
