Date/Time: Sun, 01 Nov 2026 07:11:04 +0000
The problem with Platinum
View Count: 1197
[2020-02-12 16:57:25]
User91670 - Posts: 29
imagePL.jpg / V - Attached On 2020-02-12 16:56:24 UTC - Size: 144.95 KB - 466 views
[2020-02-12 22:41:22]
This is a problem with the data provided to Sierra Chart. Refer to the information here to delete and download new data:
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method)
If this does not resolve the issue, then you will need to talk to your data provider as why there is an issue.
We know why actually this problem happens and is due to an incorrect multiplier in the CQG metadata. This is one reason why we do not recommend CQG. We recommend using this service instead:
Sierra Chart / Trading Technologies Futures Order Routing Service
Date Time Of Last Edit: 2020-02-12 22:48:25
[2022-01-28 00:37:33]
User220914 - Posts: 239
I am using denali and COMEX but no PLATINUM symbol anywhere in cme cbot or the correct one comex?
do you have a fix for this or do i need to add that symbol somehow?
thank you
[2022-01-28 01:48:24]
User90125 - Posts: 715
It's a legacy thing. The Platinum contract (PL) is with the NYMEX exchange, not COMEX.
