Date/Time: Sun, 28 Apr 2024 13:08:46 +0000
Commissions not included on Trade Window DPL
View Count: 1424
[2020-02-11 17:15:54] |
User98657 - Posts: 304 |
For some reason i cannot get the P&L on my Trade Window to include commissions. I'm using SC Exchange Data Service currently, routing through CQG (waiting for SC Routing to be set up). Symbol is F.US.CLEH20. Chart>Chart Settings>Advanced Settings> Profit/Loss Format: Currency Value (C) Global Settings>Symbol Settings>F.US.CLE?## - Round Turn Commission has a value of 4.34, an asteric next to it, and I have selected "Custom" below. Use Global Round Turn Commission is not selected. |
[2020-02-12 02:46:25] |
Refer to the documentation here for the setting you need to use: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-12 04:13:47] |
Thank you. The Round Turn Commission setting was already set. It is also necessary that when you want to use the custom Symbol Settings in Global Settings >> Symbol Settings that you have the Use Custom Symbol Settings Values enabled. Where do i find "Use Custom Symbol Settings Values"? |
[2020-02-12 06:45:40] |
This is in Global Settings>> Symbol Settings at the top left.
[2020-02-12 13:26:42] |
Thank you. Yes that too is checked, but it still wasn't giving me commissions in the DPL. I will be routing through SC instead of CQG starting today so let me see what happens today and i'll report back. |
[2020-02-12 14:17:05] |
Unfortunately the DPL on the Trade Window is still not including commissions for me.
[2020-02-13 21:17:53] |
I was wondering if there's any update available on this? I believe I've covered all the documentation, but cannot get the commissions included in my DPL on the Trade Window. |
[2020-02-14 16:46:45] |
Is this option enabled?: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-14 18:46:37] |
Yes it is.
[2020-07-17 21:11:04] |
j4ytr4der_ - Posts: 918 |
I just realized this as well, no commissions in Trade Window DPL. Everything listed above is enabled etc.
[2021-08-04 18:18:37] |
Enrico HL - Posts: 3 |
Everything is set up but the trade window (the one with the market-order button) does not use my set up commissions. I am up 96 ticks but it should be around 54.. Not sure what I am missing.. |
[2021-08-04 18:55:44] |
At one point this wasn't working for me either, I'm not sure why exactly but it works fine currently as long as this option is checked *for the chart the Trade Window is linked to*... Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) |
