Date/Time: Sun, 19 May 2024 00:37:04 +0000
Chart Replaying
View Count: 1864
[2020-02-08 18:10:39] |
User232042 - Posts: 35 |
Hello, my chart replay is not starting at the correct time. Also, on my DOM, my pulling and stacking is listed for only the current bid/ask and not my 10 levels as usual. The chart also seems to be replaying slower than real time and I am not sure why. /ES is a very volatile and fast moving index during the the day and when replayed it is very sluggish. Thanks, I really appreciate the help in advance.
Screen Shot 2020-02-08 at 9.58.11 AM.png / V - Attached On 2020-02-08 18:10:10 UTC - Size: 446.78 KB - 217 views |
[2020-02-20 11:08:52] |
In regards to the first issue, follow the instructions here: Replaying Charts: Replaying Chart from Specific Date-Time There needs to be historical market depth data recorded for the time of the replay for pulling and stacking data : Replaying Charts: Replaying of Market Depth Data And refer to this section and the following one: Replaying Charts: Historical Intraday Data Record Timeframe Effect on Replays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-20 11:09:12
[2020-02-20 17:21:10] |
Chad - Posts: 231 |
@SCE, from your 2nd statement in post #2, are you saying that historical pull/stack data can indeed be accessed so long as the historical .depth files are available, even though they don't contain that data already?
[2020-02-20 19:06:38] |
Yes that is the case. But not sure what you mean by this: even though they don't contain that data already
[2020-02-20 19:28:09] |
Chad - Posts: 231 |
I had asked about logging pull/stack data in Thread ID 48299, posts #4 and #6 (Depth of market Study), and I took it from your responses that it wasn't logged alongside the bid & ask prices & lot sizes.
[2020-02-21 05:06:40] |
Pulling and stacking information is not stored directly, it is generated from market depth data.
