Date/Time: Thu, 02 May 2024 04:29:33 +0000
Tick NYSE
View Count: 630
[2020-02-07 21:05:50] |
AndreyPoroshin - Posts: 102 |
Hello! I am temporarily using Sierra Chart package 3 through an AMP broker. Tell me, do I get Market Stats quotes in real time? I need real-time Tick NYSE data. If so, is it necessary to connect the Allow support for SierraChart Data Feeds item in the settings?
[2020-02-07 23:03:20] |
User750920 - Posts: 274 |
I do not know the answer to whether it is included or not - but have you tried adding it and see if it loads? You use the Add Symbol under the Studies and choose Tick-NYSE.
[2020-02-07 23:14:12] |
I am interested in data without delay, and only in real time. The results of testing the history and actual trading differ from each other, hence my assumption that the data is delayed for a split second. The tool does not have a $ symbol, which means that the data is delayed. I'm right? What are the options to get data without delay. If necessary, I am ready to pay Sierra directly, and not through a broker, just to get what I want. I need to understand that this will give me what I want. Date Time Of Last Edit: 2020-02-07 23:18:11
[2020-02-08 04:20:04] |
Yes the market statistics are included. Here is the documentation: Sierra Chart Market Statistics It is just a matter of opening the symbol through File >> Find Symbol>> Market Stats. The data is not delayed but if you experience a subsecond delay, that might not be unusual based on circumstances and your location. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-08 04:20:37
