Date/Time: Mon, 29 Apr 2024 18:31:36 +0000
Cummulative Delta - Volume Up/Down ticks
View Count: 729
[2020-02-07 09:25:15] |
User504193 - Posts: 38 |
I've loaded the cummulative delta studies as above, but when trying to display the current value for either study, it will only display the open? How do I get it to show the real-time volume / up/down data? I've selected 1 Tick from the settings page and no change?
[2020-02-07 17:02:26] |
We really are not understanding this. Did you make any changes to the displays of the Subgraph data? Normally you would see a Price Bar with the Open, High, Low, and Close data. Please attach an image of what you are seeing per these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-07 17:17:02] |
Sorry for the confusion, I've attached a pic of what I mean. This number only updates every new bar, but not continuously like it should?
Annotation 2020-02-08 001405.jpg / V - Attached On 2020-02-07 17:15:26 UTC - Size: 220.87 KB - 253 views Attachment Deleted. |
[2020-02-07 18:12:39] |
That label that you have highlighted for what subgraph is that for? Probably not the Last/Close subgraph.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-07 18:13:26
[2020-02-07 18:12:55] |
It looks like that is the Value Label for the Open. Therefore, it would not change except when a new bar starts. Refer to the information here for the Value Label and then turn it on/off for the Subgraphs as desired: Chart Studies: Subgraphs Tab >> Name and Value Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-08 03:02:29] |
I tried that, I tried to set it to Volume (as I presume that this is the current real time value), it is set as ignored, so I set it to visible to be able to turn on the value label, but when I hit apply, it turns back to ignore? I remember being able to see this real time updating in previous versions, has this been changed for any reason?
[2020-02-08 04:51:47] |
What is the Subgraph number that you enabled the Value Label for?
[2020-02-08 05:27:58] |
On the horizontal align drop down menu, there are no lists to select a subgraph no, just Left Edge, Left, Right, Right Edge, Left Side Values Scale, Right Side Values Scale and Label Column. I highlighted the Volume (SG5) as I guess this is the one containing the current value.
[2020-02-10 09:47:42] |
You need to set the Value Label on subgraph 4 for the Close/Last price.
[2020-02-10 09:55:37] |
Ah, that's fixed it, thanks.
