Date/Time: Sun, 04 Oct 2026 09:24:27 +0000
Live Data Feed & Trade Simulation
View Count: 809
| [2020-02-06 18:33:00] |
| User788984 - Posts: 31 |
My account is now set up for Denali Data Feed and TT FIX order routing. I am testing a custom strategy that was built for me, so I have the TRADE>Trade Simulation ON toggled to a check-mark. I also have Data/Trade Service Settings set to SC Data All Services. All works fine in simulation. If I want to go "live" and trade this strategy, what steps do I need to take to get switched to TT FIX and Denali live data? Also, can I do simulated trading using Denali Data? Thank you! |
| [2020-02-06 18:55:28] |
Also, can I do simulated trading using Denali Data? Thank you! Yes. Use Trade Simulation Mode or this service:Simulated Futures Trading Service To use the Sierra Chart order routing service follow the steps beginning at step 9 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions And be sure to follow step 20 to translate the symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-06 19:00:01
