Date/Time: Fri, 03 May 2024 19:57:39 +0000
PREVIOUSDAYCLOSE alert reference not working
View Count: 747
[2020-02-06 01:17:22] |
joshtrader - Posts: 439 |
The formula: = PREVIOUSDAYCLOSE > 0 shows "Error: #NAME?" in the alert log. By contrast, something like "= DAILYHIGH > 0" works as expected. I am connected to the data feed. Incidentally, what I really need is to see the Daily Change Percent -- is this available for an alert formula, instead of calculating it myself? Date Time Of Last Edit: 2020-02-06 02:01:07
[2020-02-06 18:07:44] |
At some point PREVIOUSDAYCLOSE changed to PREVCLOSE. We have updated the documentation to show it as PREVCLOSE now. We apologize the documentation was not up-to-date. In terms of Daily Change Percent, you would have to calculate it yourself. You can do it either in the Alert itself, or by using the Arithmetic studies to create a Subgraph that would have the value you want that you could test against. Refer to the information here for the Arithmetic Studies: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
